I've noticed that I'm unable to use the view cube while I have an item selected in stress analysis, and I have to zoom out far enough to double click on an empty space to regain focus on the view cube. Even clicking in a blank area of the model tree to deselect everything will not allow the view cube to regain its focus. It works fine in assembly, so I'm wondering if this behavior is intentional or just a bug.
Also, I am unable to use the "Select Other" command to select internal components behind parts that have been set to "Exclude from Simulation." These excluded components can't even be selected without hunting through the entire model tree list. I have to rotate the model so that I an "Included" part is in the way of the component I'm trying to select, before the "Select Other" dropdown box appears.
Is anyone else having these issues?
