Inventor Forum
BSP thread displayed as NPT thread in IDW
5 REPLIES 5
ross.hollands
343 Views, 5 Replies
Can anyone help....
I created a BSPT thread on a pipe in a model. No problem. Then when I created the IDW of the pipe and labelled the thread - it is displayed as an NPT thread. Any ideas how to overcome this?
(Please see images attached)
Ross
5 REPLIES 5
in reply to: ross.hollands
Hi Ross,
What is Thread2? Is it NPT? Is it applied to the same face? Try moving EOP above Thread2 and see if that helps.
Since it looks like a simple model could you please post? Thanks.
shekar
Hi Shekar,
Thread 1 and 2 are identicle - Both BSP.
Model attached. Hope you can help.
Regards
Ross
Hi Ross,
If I remember right there was an issue in versions earlier to R11 which was causing this. In R11 build it is fixed. The note I get in drawing in R11 is attached (both ends).
Looks like you are in an earlier build. I need to find out a few more things. Thanks.
shekar
The annotation you get is wrong too. Should say 1" BSPT I think......
I am on INV10....soon to change over.
Let me know what you find.
Ross
I found this on Mcadforums tutorial section....will try it out tomorrow.
Ross
