Is there a list of all of the icons that appear in the Browser? For exammple, the icon that indicates a drawing view has been moved to a different sheet? While I know what that icon means, often icons appear in the browser that I can't identify. A master list would be very helpful.
Solved by Curtis_Waguespack. Go to Solution.
thanks, but all icons are not listed there. For example the icon indicating move to another sheet. THis has been going on for years from Autodesk. THey create icons but don't tell you what they mean.
If I get some time I will create one for the drawing environment, thats a good idea. But normally when in the drawing managener the last thing on my mind is the browser.
Here is one I did for the Assembly browser though.
http://blogs.rand.com/manufacturing/2010/06/inventor-reference-assembly-browser-icons.html
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
Hello
Were you ever able to come up with a list for part browser?
Looking at a lower case i inside a circle.
ps, using Inventor 2015, not pro
@Anonymous wrote:
...Looking at a lower case i inside a circle.
Sick feature or sketch.
Expand the feature - is the i in circle next to sketch?
Edit the sketch - is there any pink geometry?
If you right click on the feature or sketch - do you see a Recover red cross?
Attach your file here and end all doubt.
I believe this means there's something wrong with the feature. Usually, missing the orign on the sketch. If you hit the plus next to the feature, does the sketch have the same icon?
Edit: what Prof. Mather said...
Activate your sketch and delete your edge references. They are pink, which means that reference geometry is now gone. You'll then need to constrain your sketch to new reference geometry.
^^What Aaron said.
This appears to be projected geometry from a derived component that has somehow lost it's reference.
I would simply right click on the pink geometry and select Delete - it does not appear to me that it is needed.
2014 Browser icon reference
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-6AB26BE3-0641-4195-83DB-051193A0C83A
2015 Browser icon reference
http://help.autodesk.com/view/INVNTOR/2015/ENU/?guid=GUID-6AB26BE3-0641-4195-83DB-051193A0C83A
@ronald_plesh wrote:
Anyone got a link for 2016 icons? When I look in help, all it gives me is the mold design icon list....
Thanks.
You will need to search for it like this..
They have broken it up into categories now..
