Sorry, I jumped to post in CF without finishing my thought.
It is not consistently inconsistent in that I can understand the overall length not breaking, but the dimensions on the ends are hit-or-miss. Some get left out in "real length" locations, some are brought in to "broken length" locations. I can't even justify what it's doing - I can't see the logic as a diameter on the right "BV3" stays with the model and leaves behind the fillets, but the left end "BV2" loses it's diameter and a chamfer angle, but keeps another chamfer angle and a location dim.
It's really frustrating in that you can't edit these "gotten dimensions" the way you can normal ones, by relocating the green grip points, so there is no way to fix it other than delete and re-create your own, but then again, these aren't pink/sick ... they are just dislocated.
