Hi Jerry,
You perfectly described my "nr. 2 option", making a detail view of the
assembly. But than all my dims would be lost (and I am using Ordinate
dimensions with the origin in the part that needs to be invisible)!!!
Same counts for a "Break-Out View" with a depth of 0. All the dims will be
lost.
The Broken View should be enhanced, so you can decide wich parts/side should
be visible. Is this already in R7? I do hope so...
But thanks for the quick reply!
"JerryB" wrote in message
news:86F8732983B1148B8AC8F876D24D9DA4@in.WebX.maYIadrTaRb...
> One way you could do it is to create a base view of the full vessel. Then
> use detail view to create the required view of the one end (RMB to select
> the rectangular fence). Then finally move the base view onto a different
> sheet which you can set to not print or count.
> Best regards
> Jerry Bishop
> "Hamster" wrote in message
> news:489B5341AC4654D7DAF4AF3D39995193@in.WebX.maYIadrTaRb...
> > Hi all,
> > I have a very long vessel (40 feet long, 102 inches in diameter), and I
> only
> > want to show the most left side of the vessel in my idw.
> > But when I use the Broken View option, I can "cut-away" only the middle
> > section, but I also want the most right side to be non-visible. Can this
> be
> > done directly with a Broken View?
> > If not, I will endup turning-off the visibility of the contents of my
> > assembly (with Show Contents and Show WorkFeatures).
> > Option nr. two would be making a rectangular detail view of the
assembly,
> > but than all my dims would be gone.
> > Who has some experience?
> > Thanks in advance,
> > T.
