Where can I change the default gap value in the initial display of the Broken View dialog box. I use a french version and the default value is set somewhere to .250 po instead of .250 in. I want to set this value correctly in my template.
Daniel Pinsonneault
Windows 7 64 bits french
Inventor pro 2014 french
Hi dpinson01,
Go to the Tools tab > Document Settings button > Standard tab. The listed standard controls the unit that the Break view Gap uses. So if you were wanting to change this, you'd need to go to the Manage tab > Styled Editor button and edit the standard specified in the Document Settings, then look on the General tab > Linear Units setting.
I hope this helps.
Curtis
As you can see in the attachments, the setting is "po" (pouce) for inch in french. I only have this problem with the broken view dialog box.
May be it's a bug with the french version. I got the same problem with the default standard template (Standard.IDW).
