Inventor Forum
Broken view amateur hour.
11 REPLIES 11
Message 1 of 12
156 Views, 11 Replies
I am trying to do a broken view from a section I made from the base view. I spent about 15 minutes trying to figure out what I was doing wrong. Then I searched here and find that Inventor does not allow us to do this.
Give me a break!!!!!! Please Autodesk...get your act together.
11 REPLIES 11
Message 2 of 12
Not quite the same but can't you make a detail of the breakout?
wrote in message news:5008457@discussion.autodesk.com...
Message 3 of 12
The problem is we can only have one broken view per base view. The solution is to insert one of your projected views as a base view, align the view, then create your new view and break it.
Just another workaround. (Inventor is a workaround to not having a real modeler)
Message 4 of 12
Sorry, I was thinking break outs.
wrote in message news:5008613@discussion.autodesk.com...
modeler)
Message 5 of 12
ROFLMAO
Message 6 of 12
You can not only make multiple breaks in one view, but you can break a
section view...files are at ftp.design-excellence.com uname: newsgroup
pword:inventor
Dennis
Inventor 10 SP2
modeler)
Message 7 of 12
R.Corriveau
You will have to forgive him. Someone moved his cheese. 😉
Message 8 of 12
Dennis...you don't get it...
Make a base view, project two views from it. Make a broken view of one of the projected views, and watch what happens to the other projected view.
Message 9 of 12
Yes, they both break..... projected views are associated.
However, your original question was:
"I am trying to do a broken view from a section I made from the base view. I
searched here and find that Inventor does not allow us to do this."
I was able to create multiple breaks on the section view. The left view and
the circular view are both base views. Not associated..
Is there a problem with creating a new base view?
De
wrote in message news:5008708@discussion.autodesk.com...
Message 10 of 12
Sorry . I forgot to mention the important part, that I can't create a PROPER broken view without all other child views breaking also.
No problem creating an other base view, except where do I hide it?
Message 11 of 12
Drag it off the sheet into the gray area and it won't print.
Message 12 of 12
Yes, I figured I could do that... round round workaround I get around.
