Inventor Forum
Broken dimension
4 REPLIES 4
JohnPonikvar
194 Views, 4 Replies
Broken dimension
Ok, I had to post this in CF
d94=4.875 is correct. It is a driven dimension as it dimensionaly constrained from the other end of the part. (not visible)
So what gives with d93=6.546? Both dimensions pickup from the same end. (visible)
I have tried to reconstrain it but....
JP
4 REPLIES 4
in reply to: JohnPonikvar
oh that's funny, can you post the ipt
file?
This email is never sent unsolicited. It
is only sent to you because you are lucky enough to know the
sender.
JohnPonikvar
Darin
The file is posted. Sketch 2 on Main Assembnly Holes
Funny thing. I opened the file and moved the End of Part (EOP) marker up to reduce the file size for posting. Save Copy As. 0pened the copy, to be sure all OK. Guess what, fixed the offense. So I opened the original, moved EOP up and then back... fixed.
I posted the broken one for everyon's entertainment.
Beats me
jp
Doing a rebuild all fixes it. Don't know why it got in that state though.... obviously
not a good deal.
Kent
Member of the Autodesk Discussion Forum Moderator Program
"JohnPonikvar" wrote in message
news:f1248f8.1@WebX.maYIadrTaRb...
> Darin
> Beats me
> jp
JohnPonikvar
Thanks Kent
I should have known to try the rebuild. Sure is a odd thing, they do crop up now and again don't they.
JP
