Is there an upgrade pack for British Stanards parts etc. The version we have at the college where I work has Din etc but not BS.
I have tried searching the site for the product but no joy.
Any help would be appreciated, our IT lads just got sarcastic when we asked! Must have cautht them on a bad day.
Mau
Welcome to the forum.
I am going to look into this and see if there is someone that can possibly help you.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Autodesk has been contacted and hopefully you will receive an answer or direction soon.
Hi Mau,
You may filter the Content Center Library by Standard Organization. I note that a filter for the British Standards Institute (BSI) exists.
Please note the OTHER standard content center library should be installed and included in the active project. The OTHER library contains much of the BSI content.
Have you searched the content center with this filter enabled? What type of content are you looking for?
There are also several free online part libraries that may be helpful.
http://www.3dmodelspace.com/autodesk
http://autodesk.partcommunity.com/portal/portal/autodesk/PARTcommunity/Portal/autodesk
McMaster-Carr is a great online retailer that offers CAD models for a bunch of items.
http://www.mcmaster.com/#standard-cap-screws/=p8z3ez
Finally, you can create you own custom content center libraries if you do not find exactly what you are looking for. I hope this helps.
Let me know if you have any further questions.
Cheers,
Hi there,
My configure librarys window says that the "Other" Library is "not available- can you advise what I might be able to do to resolve this (I am now working on Inventor 2015)
Many thanks in anticipation of your assistance
Richard Staite
Richard,
If you don't have the "Other" CC library installed you need to rerun the Inventor installer & add it from the Content Center library section. Or perhaps someone else there has the idcl file that you can copy over to your computer. The idcl files by default are in C:\ProgramData\Autodesk\Inventor XXXX\Content Center\Libraries
Chris
