Good day everyone,
When you remove the visibility of lines you don't want to see in a particular view in the idw, but change your mind, how do you bring back their visibilty,
other than using the undo command. Say, at a later date, you want to bring some back, how do you see what you made invisible previously.
Michael Kovacik
Alutip
(Aluminium truck load body manufacturers)
Pretoria
South Africa
Solved by admaiora. Go to Solution.
Hi Michael,
you can easily right click on the view, choose "Show Hidden Edges", the all hidden edges you remove visibility will show you, and you can click the edges that you want to see again.
Admaiora
