Hi!
I have a keyed joint in wich the key is fixed by bolts.
The problem is: I create a section, set the section participation for the shaft and the key to 'None', and I create a Break-Out in this same view with the intention to show the threaded hole in the shaft and the hole in the key, selecting the option: 'Section All Parts'. Hence this is an assembly, the bolt is in place and it is in section too because of the aforementioned command. I checked that the sectioning of standard parts is not allowed in the settings anywhere but the break-out command overwrites it. What can I do to keep my bolt out of this break out but keep the shaft and the key sectioned?
