Inventor General Discussion
Active Contributor
KFrankenberger
Message 1 of 10 (1,456 Views)
Breaking dim extension lines as they cross over other dim extension lines...
1456 Views, 9 Replies
11-29-2011 07:54 AM
I'm using Inventor 2011 and I can't figure out how to set my dimension settings so it breaks the dimension extension lines automatically when crossing over other dimension extension lines.  I saw that others say it just happens, but it is not "just happening" for me.  Can someone explain how to set my dimensions so when dimension lines cross each other one of them automatically breaks?
Thanks.
*Pro
sbixler
Message 2 of 10 (1,434 Views)
Re: Breaking dim extension lines as they cross over other dim extension lines...
12-04-2011 05:49 PM in reply to: KFrankenberger
In 2011 (and 2012), extension lines only break around dimension text.  I've never seen them break around other extension or dimension lines.
Active Contributor
KFrankenberger
Message 3 of 10 (1,419 Views)
12-05-2011 10:05 AM in reply to: KFrankenberger
That is unfortiunate. So I guess there is no way to break them? In regular AutoCAD (haven't used it in a while but I used 2008, I think) you exploded dimensions and could adjust them however you wanted after you exploded them.
Employee
t_pcoll
Message 4 of 10 (1,398 Views)
12-07-2011 06:47 AM in reply to: KFrankenberger
Hi, there was a logged a WISH item for that (DID#924303). I have added your comments to the defect.
Ladislav
Active Contributor
KFrankenberger
Message 5 of 10 (1,388 Views)
12-07-2011 08:22 AM in reply to: t_pcoll
Does that mean next time they make a new version of Inventor they might consider adding the ability to explode dimensions so you can break dim lines around each other manually?
vakhtang
Message 6 of 10 (1,368 Views)
12-07-2011 10:24 AM in reply to: KFrankenberger
actually, there is "dimbreak" command in autocad for that :smileyhappy:
Active Contributor
KFrankenberger
Message 7 of 10 (1,364 Views)
12-07-2011 10:42 AM in reply to: vakhtang
Is there a "dimbreak" command in Inventor for that? I couldn't find one.
prem
Message 8 of 10 (1,082 Views)
11-15-2012 08:19 PM in reply to: KFrankenberger
still waiting for the solution is it available in 2013
Prem
Windows 7 64 Bit
16 Gigs of RAM
Intel I7
Nvdia Quadro 3000M
enigma
Message 9 of 10 (653 Views)
09-27-2013 01:52 PM in reply to: prem
Nothing so far that I find in version 2013.
Perhaps by the next century Autodesk might hire a programmer who has actually taken some kind of drafting class.
Cadmanto
Message 10 of 10 (645 Views)
09-27-2013 02:16 PM in reply to: enigma
Have you tried searching in the Inventor IdeaStation to see if this has been suggested?  If you cannot find anything there, create one.  I know the guys at Autodesk monitor there.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! :smileyvery-happy:
Best Regards,
Scott McFadden
Inventor Professional 2013
(Colossians 3:23-25)
