We are having a pretty large annoyance where anytime you open a part with a decal, a message comes up saying there is a newer decal, and asking if you want to check out the decal. From digging a little bit I have found that this is caused by the decal being linked to the image. I however have not been able to find a way to break the link on an already created and vaulted part.
Is this possible? If so, how is this link removed?
Hi cereakes,
If you go to the Tools tab > Options panel > Links button, will that work? I think there are some links that can't be broken using this tool, but I can't recall for certain. So you might give it a try.
I hope this helps.
Curtis
http://beinginventive.typepad.com/being-inventive/2011/11/manage-links-command-in-inventor-2010.html
This does remove the link, however it also removes the image from the decal.
