Inventor Forum
Break View at an Angle
3 REPLIES 3
Ktelang
1443 Views, 3 Replies
Hello Everyone,
Any trick to make create a break view along a sloping edge.
So that the view still appears continuous rather that the one
shown in attached pic.
Config :: Intel (R) Xeon (R) CPU E31245 @ 3.30 GHz, 16.0 GB, 64bit win7
Inventor 2013 and Vault Basic 2013
3 REPLIES 3
Curtis_Waguespack
in reply to: Ktelang
Hi Ktelang,
Unfortunately it isn't possible, but it has been requested in the past. You can add your feedback at the Autodesk feedback link:
You can request enhancement and new features using the Feed Back link:
http://inventortrenches.blogspot.com/2011/01/feature-request-for-inventor.html
I hope this helps.
Curtis
Ktelang
in reply to: Curtis_Waguespack
Thanks Curtis
mechdsn
A possible "work-around" would be to break the views alignment to its parent view and then rotate the view to a horizontal or vertical orientation. Then, you can use the break view command as normal and add the angle of rotation to the view label that was generated automatically. I would typicallly add something like "VIEW ROTATED 60 CCW" (counter clockwise). Most shops can work with that without too much confusion. It would be great if Autodesk would allow broken angled views in the next release though...
