Inventor General Discussion
Valued Mentor
6 Kudos
Post 1 of 4
Break View at an Angle
295 Views, 3 Replies
06-25-2012 11:51 AM
Hello Everyone,
Any trick to make create a break view along a sloping edge.
So that the view still appears continuous rather that the one
shown in attached pic.
Config :: Intel (R) Xeon (R) CPU E31245 @ 3.30 GHz, 16.0 GB, 64bit win7
Inventor 2013 and Vault Basic 2013
1,708 Kudos
Post 2 of 4
Re: Break View at an Angle
06-25-2012 01:05 PM in reply to: Ktelang
Hi Ktelang,
Unfortunately it isn't possible, but it has been requested in the past. You can add your feedback at the Autodesk feedback link:
You can request enhancement and new features using the Feed Back link:
http://inventortrenches.blogspot.com/2011/01/feature-request-for-inventor.html
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Valued Mentor
6 Kudos
Post 3 of 4
06-25-2012 01:48 PM in reply to: Curtis_Waguespack
Thanks Curtis
New Member
0 Kudos
Post 4 of 4
01-14-2013 10:29 AM in reply to: Ktelang
A possible "work-around" would be to break the views alignment to its parent view and then rotate the view to a horizontal or vertical orientation. Then, you can use the break view command as normal and add the angle of rotation to the view label that was generated automatically. I would typicallly add something like "VIEW ROTATED 60 CCW" (counter clockwise). Most shops can work with that without too much confusion. It would be great if Autodesk would allow broken angled views in the next release though...
