Inventor Forum
Break out view of section view
4 REPLIES 4
392 Views, 4 Replies
Is it possible to do a break out view of a section view? I'm trying to do this in IV 2009 and after the command completes, my view is left the same.
4 REPLIES 4
msklein
check to make sure where your sketch is, it maynot be in the view you wanted it in. It is best to highlight the view you want in the tree then pick sketch to make sure.
msk
That's how I always do it so that is not the problem, but thanks.
Remembered to add a depth value?
Works fine here.
Peer
Iv2009 Sp2/Iv2010 Sp1
Lenovo ThinkStation S10
Intel Core 2 Quad - 2.66GHZ
4GB RAM - WinXPSp3/32Bit
Samsung SyncMaster 244T 24" 1920 x 1200
nVidia Quadro FX1700 - 512MB 6.14.11.8246
3Dconnexion SpaceNavigator 3.6.7
msklein
Peer,
I've had the same problem every once in a while, sometimes it's that i didn't get the sketch in the correct view. A couple of times the view didn't show up but when i turned on the view and scale nomenclature that showed up and then i could find the empty view box. It could be i can't remember that i got an error message about no edge found.
msk
