I have a assembly drawing with section front view. The cutting plan is at the center of shaft. However as the shaft is not supposed to section according to ISO standard. So I unsectioned the shaft. As the shaft have a screw at the center of the shaft end and also have a key. So I need to create a break out section to show the screw and key.
When I created a break out section, I need to click "section all parts" as I unsection the shaft previously. The problem is the screw and key is also sectioned. I attached the file here. May I know how shall I creat the break out section without section the screw and key.
The drawing attached here deleted all other parts. I cannot just creat the break out section on this simplified drawing attached.
EDITED & CORRECTED
At first glance you have placed & projected the images incorrectly
If you expand the tree where it say "BREAK OUT" RMB and then
REMOVE THE CHECK MARK (TICK) from the "Section All Parts" all the parts or part of a part include in the sketch area will then NOT be sectioned other that the main/front most part.
Attached your original plus my IDW as sheet 2 in the IDW file
Dear Paul
Thanks for your reply. Yes, I attached the wrong "expected break out view". The correc one is in the sheet2 of your drawing. As I removed other components in my attached file. The actual is as shown below. Base on drawing standards, shaft is not supposed to be sectioned as the cutting plane is at center. So I RMB the shaft component and select "Section participation as None" However when I create break out section to show the portion of key and screw, I have to click "section all parts". In that case, the shaft can be sectioned in the selected region, however the screw at the center of shaft also was sectioned and this is not drawing's conventional representation. How can I solve the problem?
Hi !!!
Try this:
You should be all set.
Hope this helps.
Let me know if you have any other question.
This DOSE NOT WORK in BREAK OUTS:-
As can be seen here, the section properties says NONE but it has no effect, been like this for years
Yes, it does not work in break out view. I have to click "Section all parts" when create break out view as the shaft was set "section participation as None" previously. I attached the file here. Please let me know if you have another method to solve the problem. As the file is two big, so I break into two zip file and the attachment is the first one
So there's no solution to showing "break outs" on a shaft that does not participate in a section view?
Does no one use Inventor for machine design?
