I think you have to select the part in the view, even if it's only a
single part view.
Aaron
Ltspd wrote:
> Ok, got that, thanks.
> Now, I create the sketch within the view, go to break out, select view,
> select profile (closed loop) turns blue, then specify depth, etc, but I
> never get a OK to proceed.
> Loop is closed, there is a hole back there to break to
> Now what am I not doing??
> Thanks
> Paul
> "Dennis Jeffrey" wrote in message
> news:3F672FDD.6080109@design-excellence.com...
>>You have not created the sketch WITHIN the view. Select the view, then
>>select sketch from the panel, or hit S.
>>Ltspd wrote:
>>>I have a .idw view that I need to create a break out.
>>>I create a sketch, and create a closed loop with lines. Sketch doctor
> says
>>>no problems.
>>>I go to break out and select the view and I get a error message saying "
> the
>>>view does not contain a sketch with a closed profile"
>>>Sketch doctor disagrees and so do I. What am I doing wrong?
>>>Paul
>>Dennis Jeffrey
>>Autodesk Product Consulting and Training
>>Center for Design Excellence
>>http://www.design-excellence.com
>>260-459-1311 ext 221 or 800-550-6070 ext 221
