@Anonymous wrote:
In your example, use the 'broken view' tool to move the center of the arc onto the page. See attached
Hello to all!
I'm new to the forum, and I joined because I like Inventor and because I hope to clarify any doubts that I have, and be able to give help to those who need it.
I resume this old post, because it also happens to me the same problem.
I can't get to stay linear dimensions in the drawing sheet, being very long radius to dimension.
In particular, I don't understand how to break the view with the command "broken view" to be able to keep dimensions within the sheet.
In fact, to work, the command requires physical edge, and if I click anywhere outside the shape of my piece, it tells me you didn't select any contour.
Do you know how can I do it?
Thank you so much.
I use Inventor 2014.
