I'm using Inventor Pro 2011 and I'm trying to break the association of a BOM from it's assembly. My company uses a "next assembly list" on each drawing to show the quantities and information that appear on the BOM in the next level assembly. To achieve this we insert a parts list referencing the next level, then we turn off the visiblity of all the parts except the item we want shown. The problem we've found with this is that we're using some large assemblies and Inventor slows down when it has to reference the large assembly on each drawing. All we really want to show is the single line. If we break the link to the large assembly, we feel that it will speed up the process considerably. Is there an easy way to achieve this?
Hey, Shrek... welcome.
The short answer is no, the BOM cannot be disassociated with the assembly. I'm not sure exactly what you;re trying to achieve, maybe you could post a picture with an example? There are ways to manipulte what the BOM shows, and how much goes on your drawing in the form of a Parts List... but how to do that depends on the results you are after.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Welcome to the forum.
Chris is right in that you cannot break the link between the BOM and the associated assembly.
My suggestion would be to create your BOM in Excel and then import that into your drawing and forget about the Inventor BOM.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
You could also Export from the Assembly to Excel, then edit it as needed... lots of possibilities, depends on what you want it to look like.
Chris Benner
Here is a screen shot of the "edit parts list" window where I hide all the parts I don't want shown. This parts list is actually for the assembly that the drawing's assembly goes into. We use this parts list because it shows the info for the sub assembly that we want shown on this drawing. If there's a way to create a parts list that shows the same info for this assembly with out referencing the next assembly, that would work as well. We're willing to risk needing to update the Qty manually if we can lose the link to the next assembly.
If this is still clear as mud, let me know and I'll try to clear it up some more.
It appears that I attached 2 screen shots. bom 1 shows, highlited in green, what I'm trying to achieve without the link to the next level. I'll keep those options in mind. Let me know if the screen shots bring up any more ideas.
