For Title block do the following:
1) In AutoCAD, separate the title block from the border,
save both instance to a separate file,
eg: Border.DWG, Title.DWG, close AutoCAD
or ensure the file you wish to place in Inventor is not open.
2) Open a new defined Inventor drawing template
3) In the browser, right click on a title block under Title block
and select Edit. The title block is displayed on a temporary
sheet for editing.
4) Click on "Insert AutoCAD file", select the previously defined
Title.DWG and perform your modification.
Enter and define all text and parameter as needed.
5) Save Title block to another unique name.
Do the same with your customized border.
Good Luck
Wolfe
"Allister Conyard"
wrote in message
news:FB72B2DE697BE9F52C72E5FD4513A3B6@in.WebX.maYIadrTaRb...
> Hi Gang,
> I need some help, I am just about to start a new project, where the main
> contractor has specified that a common Title Block and Border must be used
> by all parties involved in the project. They have supplied me with a
floppy
> disc containing a cad file which has title blocks for A0, A1 & A3 drawing
> sheets.
> I am having problems inserting the cad file into a new idw template, where
> am I going wrong, or is just not possible to do this.
> Thanks in advance
> Ally.
> Regards,
> Allister Conyard
> Boundary Metal Ltd
> The Steelworks
> 6 Colthrop Business Park
> Thatcham
> Berkshire
> RG19 4LP
> e-mail: allister@boundary-metal.co.uk
> Tel: 01635 879820(Direct Dial)
> Fax: 01635 879810
> This e-mail and the information contained in it and in any attachments are
> confidential and may be privileged. If you have received this e-mail in
> error please notify us immediately. You are not authorised to, and must
> not disclose, copy, distribute or retain this e-mail or any part of it .
> A list of Directors' names is open to inspection at the address below.
> Registered in England No 2544244 Registered Office Phoenix House,
> Bartholomew Street,
> Newbury, Berkshire. RG14 5QA.
> This footnote confirms that this email message has been
> checked for the presence of computer viruses, and has
> been found to be clean.
