Inventor General Discussion
Active Member
0 Kudos
Post 1 of 4
border made for A4 sheet,now i Need for A3,A2 sheet
886 Views, 3 Replies
12-03-2012 05:20 AM
i made new borde for A4 sheet and now when i am shifting to A3 Or A1, border remains same as A4 sheet size only changing.kindly reffer the  image attached.Kindly solve
*Pro
405 Kudos
Post 2 of 4
Re: border made for A4 sheet,now i Need for A3,A2 sheet
12-03-2012 07:04 AM in reply to: viveksriramr
You would have to make a border for each size. Then if you want them to change automaticaly you will have to write some ilogic code to do this.
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
2,132 Kudos
Post 3 of 4
12-03-2012 08:08 AM in reply to: viveksriramr
If you don't need for it to be fully automatic - the solution could be as simple as double clicking on the correct boarder in the Drawing Resources>Borders to change after-the-fact of creating or editing the sheet.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
*Pro
285 Kudos
Post 4 of 4
12-03-2012 06:03 PM in reply to: viveksriramr
In your border definition, you can dimension the border from the sheet corners.  This will allow it to stretch with the sheet size, as long as you don't mind
Since we stick pretty close to the ASME standards, though, which have differing border widths for different sheet sizes, we are not able to take advantage of this.  We have five different border definitions.
