Inventor Forum
BOM Thumbnail Export to Excel
52 REPLIES 52
Message 1 of 53
Raider_71
4492 Views, 52 Replies
Hi guys I have created a quick tool to export the contents of Inventors Structured BOM to Excel including the Thumbnail. One of our customers requested it and I could not find another way of doing this so I created a little app for it. Let me know what you think.
Download: http://filegooi.co.za/get2/047d021461b6ef4bb9fab9f3d4aeec35/Inv+BOM+Exp.rar
Pieter
52 REPLIES 52
Message 2 of 53
blair
in reply to: Raider_71
Nice, any way the end user can select which fields they want?
Delta Tau Chi ΔΤΧ
Message 3 of 53
Raider_71
in reply to: blair
Hi, Yes it can be done but will take quite a bit more coding. Which fields do you need?
Message 4 of 53
guyh
This will be a really nice add in.  does it work with 2011?
AutoCADM 2011 SP2
Inventor Pro 2011 SP2
Message 5 of 53
Raider_71
in reply to: guyh
Yes with both 2011 and 2012. But give it a try and let me know.
Message 6 of 53
guyh
Great.  Does it work on 64 and 32 bit?  What is the procedure\where is the tool found?  Does it work in the assembly environment or in the drawing environment.  I have installed in on Win7 64 bit Inv 2011 and can not see the function.
Thanks again,
Guy
AutoCADM 2011 SP2
Message 7 of 53
Henry.Huang
Seems not woking on a Chinese 64bit Win7 OS.
Can i ask a question about picture in cell.
Excel do not support insert a piture into a cell.  What's your approach about thumbnail in Excel cell?
Henry Huang
Product Support Specialist, Frontline Technical Support
Customer Service and Support, GCSO
Autodesk, Inc.
Message 8 of 53
guyh
in reply to: Henry.Huang
Doesn't seem to work on UK win7 64bit.
Cheers,
Guy
AutoCADM 2011 SP2
Message 9 of 53
Raider_71
in reply to: guyh
Yes it should work on both 32 and 64 bit. Its not an add-in its a standalone application and was compiled for both 32 and 64 bit.
Yes it works once you have opened and Assy file. It will do a check to make sure you have an Assy file open. Then ask you for an excel filename to export to and then export the Structured BOM into the excel file.
Just give it a go and let me know what your experience is and I can do a few tweaks where needed.
Oh and here is another download location the first one will expire soon:
http://www.mediafire.com/file/qizgs30nc6bls4c/Inv%20BOM%20Exp.rar
Message 10 of 53
Raider_71
in reply to: guyh
Ok I will have to test to make sure it works 100% on 2011. Will let you know. For the guys using 2012 let me know if you have any issues. email me direct at pieter(at)mgfx(dot)co(dot)za
Pieter
Message 11 of 53
guyh
Tested and now confirmed working with 64bit Win 7....... and working very well!  Really nice work!
If you could define the fields to export it would be even better but that is in no way a criticism.
Thanks for sharing,
Guy
AutoCADM 2011 SP2
Message 12 of 53
Raider_71
in reply to: guyh
Thanks Guy. May I ask if you tested it with Inventor 2011 or 2012?
Message 13 of 53
guyh
Inventor 2011.  Sorry should have said.
Cheers,
Guy
AutoCADM 2011 SP2
Message 14 of 53
Raider_71
Hi guys here is a new version that should be a bit more robust. Give it a try and let me know. Please remember to uninstall the previous version first.
http://www.mediafire.com/file/dojmt68232pvx25/Inv%20BOM%20Tools.rar
Pieter
Message 15 of 53
mflayler2
This would be better if you could use it inside Inventor directly and not have to leave the interface.  Kind of like Brian Ekins Parts List to Word addin.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
Message 16 of 53
Raider_71
Thanks for the feedback Mark but does it work at least?
Message 17 of 53
mflayler2
Yea it works.
Inventor 2012 with Excel 2010
Message 18 of 53
How can I make it work with Inventor 2010?
Hien
Message 19 of 53
Raider_71
Mmmm... I have not tested with 2010 at all. Have you tried running it with Inv 2010? What error do you get? Can you mail me a screenshot of the error? My email address is on the application window.
Message 20 of 53
YoniGaia
Yea. I works!
(R2011 Win7 x64)
Though it only takes the 1st Level even if I set the BOM to all Levels.
Goog Job!
Yoni.
