Inventor Forum
BOM - Structured "All Levels" not accessible, no idea why.
4 REPLIES 4
lkrenzler
584 Views, 4 Replies
I have an iAssembly where I can't seem to access all levels of in the BOM.  There is a sub-assembly I need to expand but the command is just ghosted out and in typical Inventor fashion, there's no clue as to why.
If anyone knows why this might be, I'd really appreciate the help.  Thanks!
Inventor Pro 2019 - Win. 10 - GeForce GTX 1080 .
4 REPLIES 4
Hi lkrenzler,
If I recall correctly, this is simply a limitation of iAssemblies. Here is an Ideastation idea on the subject, where you can add your feedback and show your support for improving this limitation:
http://forums.autodesk.com/t5/inventor-ideastation/bom-level-for-iassembly/idi-p/4874502
related link:
http://forums.autodesk.com/t5/inventor-general-discussion/structured-parts-lists-and-iassemblys/m-p/...
I hope this helps.
Curtis
Thanks for the help.  Wow, the whole in Inventor BOM system is just wreched.  I spend so much time fighting with it it's rediculous.  It really needs a complete makeover.
rhasell
in reply to: lkrenzler
Hi
As mentioned, this is built in, as there are so many variables to the assemblies.
There is a however a work around.
Place the iAssembly in to a new assembly.
Select the desired configuration.
This will unlock the BOM.
See an older thread here: http://forums.autodesk.com/t5/inventor-general-discussion/iassemblies-and-parts-list-only-option-in-...
Hope this solves your problem.
Reg
2024.2
Please Accept as a solution / Kudos
lkrenzler
in reply to: rhasell
Thank you very much!
