Inventor General Discussion
*Pro
sbixler
Message 11 of 13 (158 Views)
Re: BOM Reference parts & Hidden lines
01-30-2013 02:33 PM in reply to: stephentaylor33
If you set the cylinder's BOM Attribute to Purchased or Inseparable, you absolutely should not see the component parts in any higher-level BOMs.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
Member
stephentaylor33
Message 12 of 13 (141 Views)
01-31-2013 06:29 AM in reply to: sbixler
Attached here is a screen shot of our data management program (Autodesk Productstream Pro 2011) showing that it created a BOM.  This is a problem because all of our BOM's in Productstream are then without discresion exported to SAP to be used by our vendors and purchasing department.  A BOM of useless information has the potential to confuse everyone.
Also using this method should there be a BOM created at all for the cylinder? My goal is to not have any BOM created for the cylinder is that doable in any way?
Thankyou for all your help
Steve Taylor
Drafter
Stork Food & Dairy Systems
*Pro
sbixler
Message 13 of 13 (130 Views)
01-31-2013 07:33 AM in reply to: stephentaylor33
I've never used or seen Productstream, so I can't help you there.  As far as Inventor's BOM is concerned, though, an Assembly marked Purchased is a single component and shows no subcomponents.  I would hope that Productstream would treat it the same.
Sam B
