Solved by Nicolas.Bourquin. Go to Solution.
Please post a screen shot of what you are seeing, so we can identify the problen. Thanks!
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
My initial thought is to change each of the 14 sub-assemblies to Phantom type. This will promote all of the child parts up 1 level. But this may not be exactly what you want. Are each of the 14 sub-assemblies required to be shown in the Parts List as an assy?
Dear UlviEng,
Many thanks for your question.
The structured BOM in the assembly could be configured to be merged by part number.
If this is the case, here is a proposition:
>> Open the main top assembly "0831-29122013.iam"
>> Manage >> Bill Of Materials >> select "structured" tab (If necessary "View Option" button >> enable BOM view)
>> click on "Part Number Raw merge Settings" >> disable "enable Row Merge on Part Number Match" option >> ok >> done
>> go back in the drawing containing the part list >> the part list should display all the sub-assemblies.
(For information here is a link on information about "Merging rows in bill of materials":
Hope that can help.
Best Regards
