Inventor Forum
BOM / Parts List Question
6 REPLIES 6
SteveFrey
971 Views, 6 Replies
In my parts lists the length (81 inches) is displayed as 81 in.  How do I make it so it displays as 81 without the "in" suffix?
Also, is there a way to enter a formula like in excel so I can divide the sum by 12 then ROUNDUP to the nearest whole number?
Our system is counting the materials we use to the nearest foot and I'd rather export it to excel already converted.
Thanks!
Steve
Inventor 2012
Steve Frey
Inventor 2021
Windows 10 Professional 64-bit
HP ZBook 17 G6
Processor: Intel(R) Core(TM) i9-9880H CPU @ 2.30GHz
Memory: 80 GB
NVIDIA Quadro RTX5000
3D Connexion SpaceMouse Wireless
6 REPLIES 6
Cadmanto
in reply to: SteveFrey
Steve,
Edit the parts list and on the QTY column select format column.
Try editing the units here.
As far as the forumula I really don't know.
Best Regards,
Scott McFadden
(Colossians 3:23-25)
in reply to: Cadmanto
I am not sure if you would want to do this but there is a formula in ilogic to round a number to the next highest whole number.  I am 98% sure that it is "Ceil()"
Not sure if you would want to have an ilogic code to save the parameter using Ceil() and then put that parameter in the BOM?
maybe using
 "ThisBOM.OverrideQuantity("Model Data", partNumber,quantity)
Example:
ftQty=Ceil(inQty/12)
ThisBOM.OverrideQuantity("Model Data", partNumber, ftQty)
Of course  fixing the "Model Data" and the partNumber
SteveFrey
Thanks!
Steve Frey
Inventor 2021
HP ZBook 17 G6
Memory: 80 GB
SteveFrey
I haven't used iLogic so I'm afraind this won't work for me.  Thanks.
Steve Frey
Inventor 2021
HP ZBook 17 G6
Memory: 80 GB
Daren.Lawrence
The iLogic approach is a good option but if you’re not comfortable in it there are two other options I can think of: the first is to allow Inventor to round to the nearest whole value – if you don’t care about rounding down. See “Approach_1_A” and “Approach_1_B”.
In option 2 you can use the “ceil” function to round up to the next highest integer but it’s expected to be unitless (using ceil) so you need to use isolate;unit;ul like “ceil(isolate(LG;in;ul) / 12 ul)” as pictured. This will make sure that, if the length is 73” it won’t round down to 6’ but round to the next highest foot value (7). Please see the attached images (“Approach_2_A” and “Approach_2_B”).
In either case, if you don’t want to show the units, you deselect “units string”.
Please mark this as resolved if it answers your questions and resolves this. Thank you.
Daren Lawrence
Product Support Specialist
MFG Support - Inventor
http://beinginventive.typepad.com/being-inventive/
And, due to the 3 attachment limit, here's "Approach_2_B".
Daren Lawrence
Autodesk Customer Advisory Groups
