Inventor General Discussion
Valued Contributor
0 Kudos
Post 1 of 10
BOM parts and assemblies are read only
803 Views, 9 Replies
10-30-2008 09:07 AM
I have some BOM parts and an assembly that are read only and I need to be able to enter information in the bill of materials under the status column and the comments column. The BOM parts are i-parts and the assembly is an i-assembly. Is there a way to set them to read or is this a limitation?
*Dennis Jeffrey
Post 2 of 10
Re: BOM parts and assemblies are read only
10-30-2008 09:21 AM in reply to: janitor1
Are they located in a library folder or possibly copied from a
CD/DVD?  Check prperties on the parts and make sure they are not flagged
read only in Windows.
Dennis Jeffrey, Autodesk Inventor Certified
Expert
Autodesk Manufacturing Implementation Certified
Expert.
Instructor/Author/Sr. App Engr.
AIP 2008 SP2, AIP 2009-SP1
PcCillin AV
HP zv5000  AMD64 2GB - Geforce Go 440, Driver: .8185
XP
Pro SP2, Windows XP Silver Theme
href="http://teknigroup.com">http://teknigroup.com
Valued Contributor
0 Kudos
Post 3 of 10
10-30-2008 09:47 AM in reply to: janitor1
Not in a library folder or copied.
Not flagged read only in windows.
Common factor is i-parts and i-assembly.
Valued Contributor
0 Kudos
Post 4 of 10
10-31-2008 05:30 AM in reply to: janitor1
Deleted the i-assembly table to make it into a regular assembly. Can now change properties in BOM. Apparently cannot assign properties to an i-assembly or i-part.
Member
0 Kudos
Post 5 of 10
11-20-2012 08:50 AM in reply to: janitor1
I am having the same problem. I am using Inventor Professional 2012 and I have created complex iparts and iassemblies and I am not able to change the BOM structure of the parts simply because they are intelligent.  I require the tables and features that the iparts and iassemblies can create but they are coming up read only and can not modify the BOM information. Is there a way to change the read only aspect of an ipart or iassembly?
870 Kudos
Post 6 of 10
11-20-2012 11:32 AM in reply to: robert.henderson
Are you using Vault?  Are any of these parts Content Center parts?
ChrisB / Twitter
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cadtipstricks.wordpress.com//
Member
0 Kudos
Post 7 of 10
11-20-2012 11:45 AM in reply to: cbenner
I am not using Vault, all files are on my local server.  Also all parts and assemblies have been created from nothing.  I work in the Rail Industry, for example one of my iassemblies is a bungalow.  This bungalow has 6 options, these options change the physical size of the bungalow, this bungalow comes with receptacles, lights, light switch(es), exhaust fan, heater, thermostats, shelves, and a distribution panel.  This will show up as a single item on my BOM, but there is a lot of intelligence (equipment moves or gets added depending on the selection) within my assembly and I can not change anything on my BOM because its coming up as read only.  This particular iassembly contains parts, iparts, and iassemblies all of which I have created since my content is very unique.  Everything works as I want, except the BOM.
870 Kudos
Post 8 of 10
11-20-2012 12:02 PM in reply to: robert.henderson
Any chance of posting the assembly or any of the files?
ChrisB / Twitter
Member
0 Kudos
Post 9 of 10
11-20-2012 12:09 PM in reply to: cbenner
I've attached the bungalow that would be set up in the master BOM as a single item. This iassembly will end up in a template which I am setting up.
Member
0 Kudos
Post 10 of 10
11-21-2012 07:25 AM in reply to: robert.henderson
Sorry about that,
I did not pack and go my assembly.  I know why its read only, basically because the bungalow assembly has options since its intelligent that information could change when you put in into another assembly. I can put properties into my table such as the description, however I do not see an option to put my custom iproperties in the table, that’s where I have hit the road block at this point.
The bungalow has been posted on our FTP site, details noted below. Using Internet Explorer access through address: https://www.hmmftp.com/
Username=ro6251
Password=5ONSUEkV
* Data Stored here will be purged on Sat Nov 24 10:03:02 EST 2012.
