Inventor General Discussion
Valued Contributor JM.
Valued Contributor
JM.
Message 1 of 3 (252 Views)
BOM Grouping
252 Views, 2 Replies
09-18-2012 12:52 PM
I frequently need to list several parts with the same part number but with different discriptions and part formulas.  Inventor keeps grouping them even when I turn the group fuction off.  I just want inventor to list them by 'item' and I will sort them as required but I can't find a way to make this work.  Is it possible to do this?
Yes, you can disable the Bom Roll Up function. Here's a link to a skill builder on BOM in general: http://download.autodesk.com/us/inventorprofessional/pdf/skillbuilder_bom_structure.pdf
Pg15 explains what causes it to occur which is important to understand.
This WikiHelp link explains how to enable/disable Row Merge:
http://wikihelp.autodesk.com/Inventor/enu/2012/Help/0073-Autodesk73/0611-Drawings611/0633-Drawing_633/0642-Parts_li642
Product Support
dave.anderson
Message 2 of 3 (213 Views)
Re: BOM Grouping
09-26-2012 01:45 PM in reply to: JM.
http://wikihelp.autodesk.com/Inventor/enu/2012/Help/0073-Autodesk73/0611-Drawings611/0633-Drawing_63...
Dave Anderson
Premium Support Analyst – DLS Mechanical Design
If I have answered your question, please "Accept Solution" so others may benefit as well.
Valued Contributor
JM.
Message 3 of 3 (206 Views)
Re: BOM Grouping
09-26-2012 02:25 PM in reply to: dave.anderson
Thanks - the links describe the problem I have been having.
