I use this (similar) when I export my BOM list.
I want to export the BOM list "structured" with "All Levels".
How do I do this and use a template?
I like to use the iLogic.
Is it possible to "Expand All Children" in the parts list of DWG with a command from the iLogic.
If I export it from. iam then I can not use my own made template.
'-------------Start of ilogic ------------------------------------------------
'get the path and name of the drawing file
path_and_name = ThisDoc.PathAndFileName(False) ' without extension
'define oDoc
oDoc = ThisDoc.Document
'specify the drawing sheet
oSheet = oDoc.Sheets("Sheet:1") ' sheet by name
'oSheet = oDoc.Sheets(1) ' first sheet
' say there is a Partslist on the sheet.
oPartslist = oSheet.PartsLists(1)
' create a new NameValueMap object
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
'specify an existing template file
'to use For formatting colors, fonts, etc
oOptions.Value("Template") = "C:\Temp\PartListExport.xls"
'specify the columns to export
oOptions.Value("ExportedColumns") = "QTY;PART NUMBER;DESCRIPTION"
'specify the start cell
oOptions.Value("StartingCell") = "A3"
'specify the XLS tab name
'here the file name is used
oOptions.Value("TableName") = ThisDoc.FileName(False) 'without extension
'choose to include the parts list title row
'in this example "Ye Old List of Parts" is written to the StartingCell
oOptions.Value("IncludeTitle") = True
'choose to autofit the column width in the xls file
oOptions.Value("AutoFitColumnWidth") = True
' export the Partslist to Excel with options
oPartslist.Export(path_and_name & ".xls", _
PartsListFileFormatEnum.kMicrosoftExcel, oOptions)
'-------------End of ilogic ------------------------------------------------
