These will be family table parts and assemblies but just to keep it simple for now lets look at non family table parts and assemblies.
The attachment is a drawing of a casting, a machine part that is made from the casting and an assembly that uses the machine part.
The casting will have a drawing that has no BOM.
The machine part will have a drawing that has a BOM that calls out the casting.
The assembly will have a drawing that has a BOM that calls out the machine part.
In the models:
I would like to have an assembly and a machine part the is linked to the casting part so if the casting part changes the machine part and the assembly changes.
In the drawings:
I would like to be able to use existing iproperties or user defined ones and use one parts list style so I can create a drawing of the casting, create a drawing of the machine part where the bom calls out the casting description and part number and a drawing of the assembly that calls out the machine description and part number.
How do I set this up to accomplish what I want.
Hello BDUB2012,
I saw your posting and I was wondering if you have found a solution?
I am currently in the same situation and I interested in hearing your progress.
Thank you,
I would recommend NX.
In NX, basically you can either promote the solid casting and /or copy solid body to the next higher level assembly which would be machined part in your case and you should be able to modify it using modeling tools.
Try out trial version available on Siemens website
I use Inventor's Derive workflow.
Note: this method will not allow you to drill down to the casting part in a structured Parts List or assembly BOM. I use partnumber-casting for the casting part filename and partnumber for the machined part filename to help me remember the link between the casting and machined parts.
Steve Walton
