Inventor General Discussion
BarryZA
Message 1 of 8 (250 Views)
BOM all levels greyed out
250 Views, 7 Replies
11-27-2013 03:30 AM
First I do this:
then I open a new drawing, put down my assembly and get this:
They say a picture says a thousand words, and after countless re-tries I'll let them do the talking. That way there's no swearing involved :cathappy:
*Pro
jletcher
Message 2 of 8 (242 Views)
Re: BOM all levels greyed out
11-27-2013 03:57 AM in reply to: BarryZA
Do you have any balloons on the assembly?
 If you do you will have to delete them then you will have control again.
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
-niels-
Message 3 of 8 (237 Views)
11-27-2013 04:09 AM in reply to: BarryZA
For as far as i can see everything is in order.
If you set "all levels" in the BOM then the part list will take the settings from the model.
The only time when you can select "all levels" when placing a parts list is if you haven't activated it in the model yet.
Any changes after placement/activation need to be done in the BOM anyway, so your workflow seems fine to me.
Using IV2014 Pro SP2 - upd.1, Win7-64bit
*Pro
jletcher
Message 4 of 8 (232 Views)
11-27-2013 04:45 AM in reply to: -niels-
  Never had to do this before is this new in 2014?
James Letcher
BarryZA
Message 5 of 8 (231 Views)
11-27-2013 04:46 AM in reply to: -niels-
I used a clean drawing, no balloons, no nothing.
I can only imagine that something has slipid in somewhere. I'll play around with another assembly this evening..
-niels-
Message 6 of 8 (223 Views)
11-27-2013 05:07 AM in reply to: jletcher
No, it's not new.
You do not "do this", it's something that gets done for you.
But maybe i'm not clear enough or i'm missing something...
So for clarity:
1. in the assembly open the Bill of Materials.
2. check if the Structured tab is enabled.
(like barry's first image)
If it's enabled like that, when you place a Parts list on the drawing the option for selecting "all levels" will be greyed out.
To see what i meant by my quote do the following:
1. in the assembly open the Bill of Materials and make sure the Structured and the Parts only tabs are disabled. (no lists shown)
2. go to the idw and place a parts list, you should now have the option to select which kind of BOM view you want.
Hope this is more clear...
BarryZA
Message 7 of 8 (216 Views)
11-27-2013 05:24 AM in reply to: -niels-
DONE!
Now I can RMB on the parts list edit parts list and "+" the sub-assembly(ies) I want to.
Thank-you Niels.
-niels-
Message 8 of 8 (214 Views)
11-27-2013 05:33 AM in reply to: BarryZA
Glad you got it sorted.
I'm kinda left with the feeling i didn't understand your initial problem, but that's alright.
Just remember that you can always go back to the Bill of Materials in the model and change the properties from there.
