I have made an ipart and I want to use it with Bolted connection. Is that possible??
It`s a T-nut and I have made the nut available in content center...
/Kristoffer
Well, without knowing anything about your Inventor setup or what release, I'd say there's only one way to find out. Start an assembly... and give it a shot! LOL... then if it's not working you can come back and give us a bit more detail on what steps you took to this point, so we can help you through it. It SHOULD work, you can definitely add your own fasteners to bolted connection. The question is wether you did everything right up to this point.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
