Inventor Forum
Bolted Connection
4 REPLIES 4
Talayoe
269 Views, 4 Replies
Bolted Connection
Hello all,
I on occasion run into it where I select bolted connection, run thru the start plane/holes/terminate plate (and follow pattern if applicable) and then select the fastener type only to have machine screws show up in the list. Wagon heads and slotted heads, ect. Usually in the top right of the pop up there is a drop down that you can select type of bolt required. In some cases it does not appear and only gives me the option to have these kind of bolts, when what I really want is a HH or SHCS (for example)...but apparently are unavailable?
Why is this, and is there a way to get these to show? Typically I use "by hole", if it makes a difference.
Tks!
-Randy
Inventor 2017 PDS
4 REPLIES 4
brendan.henderson
in reply to: Talayoe
Not sure what is happening here. A few screen shots would help immensely. Do you have the Diameter you want in these CC families?
FYI, 1 of the best things to do to make the BC Accelerator useful is to save (Add) your completed fastener sets to the Templates Library. Then it's just a simple matter of selecting the Placement options and then applying (Set) the Template to apply to it. Saves a lot of time and frustration.
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Talayoe
in reply to: brendan.henderson
Sorry for the long delay. I have been out of the office a lot.Please see the attached picture.
-Randy
Inventor 2017 PDS
mercerc
Your last statment was telling. By selecting by hole the Bolted Connection looks a the hole size and feeds back what it has for those sizes. This is why you sometimes see what you do.
Brendens suggestion of creating the templates for the hardware and holes is a good answer to addressing your needs.
Charlie M
Inventor Product Support Specialist
Hello Brendan,
Do you really use the Bolt Connection? I've wanted to but don't like how it makes sub-assemblies with dumb file numbers. Boltconnection1.asm
How do you handle that? I also see it makes new folders for each connection named Design Accelerator. It maybe just the way we structure our folders in Vault that makes it look so messy.
Just wanted your take on how you handle all this.
Thanks for some input.
Douglas DuPont
Inventor 2016 Pro, Vault 2016 Pro
Quadro M4000
Windows 10 64 Bit
