Bolted connection, clevis pin and bearing are all not working for me. I can go through the steps of selecting the start plane and then the circular reference and the termination point. That is all successful but the bolt doesn't appear, whether I use a clevis pin or a bearing, I get the same result.
Working with sheet metal or FrameMaker all work fine. My content center shows all the bolts, clevis pins and bearings. The content center seems to be working fine. I have read many posts about this issue but have not seen a resolution, and can't seem to figure it out myself. Any help would be appreciated. I'm using inventor 2011.
Solved by cbenner. Go to Solution.
If you see a hole setting in red, It seems you have to select an appropriate thread diameter value if you are using any placement settings other than by hole.
Try changing the diameter, right under the norm of the bolts. It worked for me, i had 0.25mm so i think it couldn't find anything that size.
