Inventor General Discussion
0 Kudos
Post 1 of 9
Bolted Connection - Failing to stay constrained
501 Views, 8 Replies
01-11-2010 01:35 PM
I've been having an issue with my bolted connection - when I check to follow pattern or if I pick multiple holes the bolted connection doesn't stay locked down by constraints - it still wants to rotate about the first picked hole axis. When I have used bolted connection in the past it would always remain completely constrained. Would anyone happen to know why this is? Thanks
*Blair Stunder
Post 2 of 9
Re: Bolted Connection - Failing to stay constrained
01-11-2010 04:08 PM in reply to: schwebby
Version and SP's
IV2010-Pro-sp2
Vista Business 64bit Sp2
Core i7 950 @ 3.07Ghz
12Gb DDR3-1600, 240Gb (4 x 60 Gb SSD - RAID0)
Quadro FX3800 - 191.78
SpacePilot 3.8.3 / 6.8.1
AVG9.0
"schwebby" wrote in message news:6316345@discussion.autodesk.com...
0 Kudos
Post 3 of 9
01-12-2010 07:46 AM in reply to: schwebby
Sorry - Inventor 2010 SP 1
01-13-2010 04:53 AM in reply to: schwebby
Hello
unfortunatelly , as far as I know it is as designed. Workaround for that is
to add a new own constrain on a one bold in the pattern to constrain ti with
a part. Then it works well. And also you have to check if something changes
with pattern that BC is on right possition.
regards
"schwebby" píše v diskusním příspěvku
__________ Informace od ESET NOD32 Antivirus, verze databaze 4763 (20100112)
__________
Tuto zpravu proveril ESET NOD32 Antivirus.
http://www.eset.cz
__________ Informace od ESET NOD32 Antivirus, verze databaze 4766 (20100113) __________
http://www.eset.cz
0 Kudos
Post 5 of 9
01-14-2010 07:23 AM in reply to: schwebby
I find this hard to believe - it has worked in the past where the bolted connection is locked down - I have been noticing this issue for the past 3 weeks - thought it was maybe something with old projects i'm working in?
0 Kudos
Post 6 of 9
01-20-2010 08:23 AM in reply to: schwebby
well - after trying a new project and assembly the bolted connection still rotates about the selected hole axis. I'm thinking it might be the way Inventor 2010 does the bolted connection - I'll have to try it again in Inventor 2009 and see if the bolted connection stays constrained.
Valued Mentor
112 Kudos
Post 7 of 9
01-31-2010 10:01 PM in reply to: schwebby
I too am having this issue, and I am unable to add an additional constraint without getting the "overconstrained" prompt. I'll spare the long stories but it seems the easiest thing for me to do is recreate this bolted connection each time after altering the model. Is there any news or information about why this would do this or what I could do differently?
IV2010 SP1
Vista Ultimate SP2 Edited by: jeanchile on Feb 1, 2010 6:01 AM
Inventor Professional 2013 (SP-2.3), Product Design Suite Ultimate
Desktop: Intel Core i7 3.4GHz, 16.0 GB RAM, Windows 7 Ultimate SP-1, 64-bit OS, (2) GeForce GTX 580 (331.81), Space Pilot Pro (3.16.1)
Laptop: Intel Core i7 3.9GHz, 16.0 GB RAM, Windows 7 Pro SP-1, 64-bit OS, GeForce GTX 780 (331.81), SpaceNavigator (3.17.7)
1 Kudo
Post 8 of 9
06-03-2014 03:42 AM in reply to: jeanchile
I've got the same problem with Inventor 2013 SP2. When using the "Follow pattern" all the bolts created using the same "Bolted Connection" can rotate around the axis of the first bolt.
0 Kudos
Post 9 of 9
07-03-2014 06:12 AM in reply to: robin.werneskog
I am having this problem as well with 2015 Professional. We upgraded from 2012 and it worked just fine there. I have even noticed if I open legacy assemblies that have not been migrated that the constraints are broken on those as well. I really hate to think the solution is to just start adding extra constraints that we previously have not needed.
Scott Miller
Inventor Professional 2015 x64
AMD Phenom II x4 965 (3.41 ghz)
16 GB ram
Quadro Pro 2000, 1GB
