Inventor 11 Service Pack 2
Windows XP SP2
Vault 5 SP1?
We are using Inventor 11 with the vault. We are using content center from in the vault. (not a local content center)
We are using a bolted connection in an assembly. When we attempt to add the assembly to the vault it says
[ERROR] The following files already exist in the vault and cannot be added due to vaulting restrictions:
1_4-UNC.ipt
The part is a NUT and the NUT is identical to the one in the vault already...but the path is different.
The one that is already in the vault is in
C:\WORK\Standard Libraries\Content Center Files\en-US\AS 2465 - Inch
The one we are trying to add is
C:\WORK\Standard Libraries\Content Center Files\en-US\Hex Nut - Inch
Why does it not reference the same item from the vault.
Support said that we could turn off unique file names, but I don't understand why I should do that?
Does Content Center use unique file names in Inventor11 SP2?
TIA
