Inventor Forum
Bolted Connection Content Center files give duplicate file error in vault
2 REPLIES 2
265 Views, 2 Replies
Inventor 11 Service Pack 2
Windows XP SP2
Vault 5 SP1?
We are using Inventor 11 with the vault. We are using content center from in the vault. (not a local content center)
We are using a bolted connection in an assembly. When we attempt to add the assembly to the vault it says
[ERROR] The following files already exist in the vault and cannot be added due to vaulting restrictions:
1_4-UNC.ipt
The part is a NUT and the NUT is identical to the one in the vault already...but the path is different.
The one that is already in the vault is in
C:\WORK\Standard Libraries\Content Center Files\en-US\AS 2465 - Inch
The one we are trying to add is
C:\WORK\Standard Libraries\Content Center Files\en-US\Hex Nut - Inch
Why does it not reference the same item from the vault.
Support said that we could turn off unique file names, but I don't understand why I should do that?
Does Content Center use unique file names in Inventor11 SP2?
TIA
2 REPLIES 2
The short answer is NO.
The real fun happens when IV decides to to swap a SHCS (1-2.ipt) with a Hex
or Shoulder bolt (1-2.ipt) without any warning whatsoever to the user.
(because one or another is missing)
There is a patch (more like a complete new install) you can get through your
reseller that is a CC with unique filenames.
Just turn off the Unique Filenames switch in the Project File and get on
with your day.
QBZ
rjsurdyk wrote in message news:5626885@discussion.autodesk.com...
Read this topic:
http://discussion.autodesk.com/thread.jspa?messageID=5232359
Contact Roy Chick (Autodesk) for more information
(FirstName.LastName@autodesk.com)
T. Ham
CAD Automation & Systems Administrator
CDS Engineering BV
HP xw4300 Workstation
Dual Pentium XEON 3.6 Ghz
4 GB SDRAM
NVIDIA QUADRO FX 3450/4000 SDI (Driver = 8.4.2.6)
250 GB SEAGATE SATA Hard Disc
3Com Gigabit NIC
Windows XP Professional SP2
Autodesk Inventor Series 10 SP3a
