For the Kind Attn:- Mr JD Mather Sir
WHICH TYPE OF CONSTRAINT SHALL BE CONSIDERD FOR BOLTED CONNECTION IN INVENTOR STRESS ANALYSIS environment
Thanking you,
Abhinay
You can apply a fixed connection when you run your simulation. Since there are no degrees of freedom left because the bolt connection covers them all, you have to assume the fixed connection for both, stress analysis and frame analysis
