I have used Inventor off and on for 10 years now. I have never seen this.
In the hole window, under placement, you have a few options, one of which is the concentric option. How much more difficult would it be to add a bolt hole pattern, on a specified B.C., using this as a base, seeing how most bolt hole patterns revolve around a pipe flange or something simular. I know I could just make a sketch and do hole from sketch but something like this would be much quicker. It would also allow us to remove the occurrence that we do not need.
So it would be like Drawing a sketch, doing a hole, then using circular pattern, (if not done in the sketch). The issue i have noticed in doing it in the sketch is that a single occurrence cannot be removed.
I think I understand. You'd like an option in the hole command to specify a bolt circle pattern. It would ask for the number of holes, size of the holes and the BC diameter? That would be very handy. Are you familiar with the Inventor Idea Station?
http://forums.autodesk.com/t5/Inventor-IdeaStation/idb-p/v1232
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Sounds like an excellent idea to me.
So ubiquitous in part design, especially tooling, makes you wonder why it isn't already there.
