I only use CC to make a custom screw/bolt whatever, give it a name that
makes sense to all where you work, save it in a folder like "Hardware". Then
when I need to use a screw, place in assembly and I just use the "Insert"
assembly constraint. This is much faster for what I'm doing. This also
avoids all the "pack and go" hassles. I don't even use pack and go anymore
if I can avoid BC and CC, I can just save the folder and move it where ever
I want.
Russ Tanner
wrote in message news:5531852@discussion.autodesk.com...
When inserting a bolt connection requiring a coutersink or counter bore, the
bolt is not placed flush and is left standing.
Is there a setting somewhere that corrects this problem?
