Inventor Forum
Bolt diameter is inactive in Bolt Connection Component Generator
1 REPLY 1
valdas
418 Views, 1 Reply
I have some problems with Bolt Connection Component Generator. For placement I choose Concentric, i choose all references, but I can't select Diameter. It is stuck to 10mm and i can't change it.
Am i doing it wrong or what?
I am using Inventor Profesional 2013
Print Screen
Thanks for answers
1 REPLY 1
AndyWallace
in reply to: valdas
The ENABLE CALCULATION button, upper right just under the X, is selected.
This just happened to me and I couldn't change hole size even though the choice was "by hole". Even though my hole in the parts was #8, the bolted connection wizard was stuck at #2 until I unselected calculations.
Unselect calculations and then you should be able to select a new size.
Oddly, now that I've unselected it, and created a bolted connection, I can't seem to duplicate the problem, even after creating a new assembly.
Andy
Andy Wallace
Autodesk Inventor (2016) (3 years)
previously Solidworks (6 years)
Tags (1)
