Here's another way to do it...... see attached.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
260-399-6615
Instructor/Author/Sr. App Engr.
AIP 11SP3, AIP 2008 SP1, PcCillin AV
HP zv5000 AMD64 ( modified)
Geforce Go 440, Driver: .8185, 2GB RAM
XP Pro SP2, Windows Classic Theme
"Dennis Jeffrey" wrote in message
news:5693189@discussion.autodesk.com...
If I delete his part features, then create a workplane from the two vertical
edges, use that WP as the sketch plane, I can create the extrude feature
correctly. See attached...
260-399-6615
wrote in message news:5693158@discussion.autodesk.com...
Shouldn't be necessary. I can create a new derived part from the sketch
with no trouble. I use this technique all the time and never saw this
problem before. Although I usually change my derived sketches to
construction and sketch my own close boundary overtop the derived or
projected geometry.
