Have you had time to explore the functionality of exploding your dimensions
during conversion?
I use the dwg standards layer translator to convert layers. It forces color
and linetype bylayer. Then just select everything on screen, and change
the lineweight to , while everything is still selected, I run the
express tool: Express>Modify>delete duplicate objects. (overkill at the
command prompt)
That should get you going in the right direction. Still alot of steps, but
once you get on to it you can make some pretty useable dwgs.
Cory McConnell
BJ Pipeline Inspection
"Richard Hintehoeller" wrote in message
news:3DCD9D16.1010500@hfx.eastlink.ca...
> OK folks, I have a confession to make. When I said the translation from
> IV to ACAD was pathetic, the comment was based on IV5.3.
> While browsing the web today, I saw an article about how IV6 has
> improved the translation. Fully prepared to eat crow on the issue, I
> decided to try a translation in IV6.
> So I tried it. It now requires even more steps to make a usable drawing
> than it used to! I now have to worm my way through groups and I have to
> re-define the title block to get some semblance of a usable drawing file.
> Why? One word - ByLayer. If, instead of hard coding that the colour be
> black (assuming a white background), it would be ByLayer, most of my,
> and I hope I speak for many of us, problems would be gone.
> I know that later versions of AutoCAD have introduced the concept of
> line weight, but that's not practical for everyone. For example, I'm
> currently working with a company that is using an old pen plotter.
> Their only way of controlling line weights is by assigning colours to
pens.
> Now, and I address this to the IV developers, imagine the steps one has
> to go through to explode every group and redefine every block just
> because a colour is assigned to every entity, instead of following
> standard ACAD practice of assigning ByLayer.
> Please, I'll bet that modifying one line of code, you could save us from
> eternal purgatory.
> Richard
