A customer is trying to export a model for use in Revit. When he goes to the Environments tab -> BIM Exchange and the dialog opens... He has no option for RFA files... Only ADSK. Not sure what is going on.
Any ideas?
Solved by pcrawley. Go to Solution.
You can export as ADSK and bring that into Revit. That's no problem. (It's not very useful, but it works.)
If you want to create a Revit family file (.RFA) then you have to:
It does work well - but Revit is a very poor relation to Inventor in terms of modelling capability, so your resulting RFA model may look a bit like a Lego brick when you're done!
It appears as though the idea of a .RFA file is for it to be as small (filesize) as possible. I guess this because it could be used thousands of times in one Revit model, and unlike Inventor where it just references the file, Revit creates one huge model file that contains everything. So, keep it really simple!
I just remebered this video too from the great guys at Cadline in the UK.
http://www.youtube.com/watch?v=b77aqqEnq5I
PC-
Thanks for the replies.... I didn't even think about the possibility of him having an assembly open. I'll go through these steps with him...
Thanks for your help-
Jess
