I am using an .idw file for our drawings, is there a way to set it up to input the weight per ft of the material and the total weight in the BOM of the .idw file?
Solved by Cadmanto. Go to Solution.
Matt,
Take a look at this link. It shows some of the basic steps you would take to do what you are looking to do.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
very cool, thank you.
