I have been working with Inventor for about a year now and I have yet to learn how to make a good smooth bevel.
I need to do the cut out on the back of a startocaster.
Pictures and IPT included.
I looked on you tube and could no
t find what I was looking for.
Mark
You could Sweep a line along the arc creating a surface body that you could then use to Sculpt the bevel.
Post back if you can't figure out this solution, or if this solution isn't appropriate.
I recommend that you also install Service Packs 1 & 2 for 2014.
As I looked over the model I also noticed there were a fairly large number of missing Tangent Constraints (in my opinion) in Sketch2.
I would expect this to cause problems later on.
My training is very basic so alot of the basics get missed.
I will constrain the nodes you pointed out.
When you say "You could Sweep a line along the arc creating a surface body"
I am thinking a drawing then revolve cut.... I am going to do it now and see how it turns out.
I did notice that I am unable to flit th top face of the guitar. Is that because of the constraints?
Thanks for the help.
Mark
mrmdk187 wrote:I did notice that I am unable to fillet the top face of the guitar. Is that because of the constraints?
That, and the fact that you have double arcs not meeting at endpoints.
Unfortunately - it will be very difficult to fix now. You need to develop a disciplined modeling approach that resolves problems as you create each sketch entity, rather than creating a whole bunch of stuff and then try to fix the problems.
Get lazy - do it right the first time. There is no economy in skipping steps.
I started from scratch and fixed every issue I could find.
I am trying to filet the edges and can not seem to get them to work.
I tried a sweep but am still having an issue.
Any ideas?
How does my work flow look on this one? Any advice?
I have learned so much with this project.
I love learning. What a powerful tool.
Mark
Okey I downloaded the service packs but I seem to be missing the install program....?!
I have looked through the help files.
Can somone please point me to the download link for the install program.... I have no idea what happened to the original.
