Inventor Forum
Bevel Gears with straight teeth
4 REPLIES 4
garylynn
761 Views, 4 Replies
Is it possible, using Design Accelerator to have Bevel Gears with straight teeth?  I've tried every combo I can think of, and they are always curved teeth.  Gears are not my most knowledgeable subject.  I usually have the engineers produce the specs, & I get to draw them - they are not happy with the pictorial results.
Inventor Product Design Suite Premium 2013
Thanks in advance.
4 REPLIES 4
blair
in reply to: garylynn
Or just create another gear on the side of the gear with the beveled teeth and project the side profile and extrude to get a straight gear.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
garylynn
I think I've figured it out.
Talayoe
Would you mind sharing the answer? I have pondered this too... The higherarchy here does not like the said pictoral results of a helical gear either.
tks!
-Randy
Inventor 2017 PDS
garylynn
in reply to: Talayoe
By setting the Helix angle to 0 degrees - accepting the error messages that pop up & continue.  The gears/teeth are generated & seem pictorially satisfactory.  I wouldn't pass it on to a CNC without lots of notes, though.  I was trying to put the pitch angle as the helix angle & that's what screwed me up.
