There's a pdf file in the CF newsgroup of a simple bent tube with some holes
in it.
Many of our parts are similar to this. A tube, say 1.00 square, cut to
length, holes drilled, and formed to a curve.
I'd like to model this in a way that is easy to change as size/radius/hole
count changes. Here's what's important:
Tube true length (the true arc length of the tubing after it's formed to a
curve)
Radius
Number of holes (both on the radiused face and on the top (flat) face)
I'm fine with creating the tube and setting up variables for arc length &
radius, but the holes give me a problem. I'm not sure of the best way to
put those on--the ones on the radiused face.
An option that I like would be to model the tube straight (before bending),
then bend the model on the radius. I'm not sure how to do that... I tried
with sheetmetal tools, but it didn't work. If I did it that way, I could
show a drawing view that's the unbent tube w/ all dimensions, then a
secondary view of the curved tube.
So, anybody here have advice on a good way to do this? Anybody want to
model something quickly? I appreciate your help/advice. Thanks...
Brian
