Inventor Forum
Best way to model a standard gauge track?
2 REPLIES 2
sanabriaerik
1438 Views, 2 Replies
Is there an easier way to model train tracks from standards with somthing like a generator instead of having to draw the cutouts in a sketch? With european standards or american standards?
2 REPLIES 2
LT.Rusty
in reply to: sanabriaerik
Sure is.
Model one rail, and set up all the parameters that you need to modify to change it into a different standard.  Create an iPart that will incorporate your various standards, and then publish it to a custom content center library.  Set it up with appropriate key values, and you'll be able to insert whatever standard rail you want, at whatever length you need it to be.
Rusty
swalton
in reply to: LT.Rusty
I did not even bother with the iparts and Content Center.
I use AREMA rails.  LB foster has very nice pfs showing the exact rail profile.
I made a 1' long segment of each weight I needed.  Each time a need a new length, I save a copy of the proper 1' long start part and edit the length of the extrusion.  Easy.  I don't have to remember how to migrate the CC parts when I move between releases and I don't have to fight Vault and iparts.
Steve Walton
Inventor 2023
Vault Professional 2023
